Board2PDF: Failed to load PyMuPDF
When I try to use the plugin with the “PyMuPDF” library, The error is displayed in the image below, also the “PDFCropMargins” doesn’t work.
also, I upgraded PDFCropMargins installed on my machine before Creating the Topic , and doesn’t effect.
OS : Windows 10
Kicad Version : 8.0.1
Board2PDF Version : 1.8.0
What is the solution?
Support
First search the KiCad forum to see if someone else has asked the same thing. If not, post your question in the forum and tag me by writing @Albin. That way I will see your post and answer as soon as I can.
Hi @safecv
Have you installed pdfCropMargins from the KiCad Command Prompt, and not your default terminal?
More information in the Wiki:
Thanks sir @albin and sir @RaptorUK,
i Can’t find “Kicad Command Prompt” in Start menu.
Edit : I ReInstalled Kicad and "Kicad 8.0 Command Prompt " is added to Start menu , and my Problem is Solved with @albin Solution.
