I’m currently working on a grid shape board with cutouts. I stumbled a lot over malformed outlines during the creation of the board outline. I also tried to reproduce the issue but can’t do by intent. Finally I made it and started routing. I checked the outline several times by just using 3D view and suddenly, without any changes to the edge.cut layer, the board outline became malformed again.
I tried “Tools->CleanUp Graphics->Fix discontinuities 0.1mm” without success.
I restored a working version from the backup folder.
Note: I deleted everything but the edge.cut to protect IP of my customer.
Working:
Matrix_MalformedOutline_Before.kicad_pcb (460.5 KB)
Broken:
Matrix_MalformedOutline_After.kicad_pcb (631.8 KB)
Version Info
Version: 9.0.2, release build
wxWidgets 3.2.8
FreeType 2.13.3
HarfBuzz 9.0.0
FontConfig 2.15.0
libcurl/8.13.0 OpenSSL/3.3.3 zlib/1.3.1 libidn2/2.3.7 libpsl/0.21.5 nghttp2/1.65.0
Platform: Freedesktop SDK 24.08 (Flatpak runtime), 64 bit, Little endian, wxGTK, X11, KDE (One-Time Launch), x11
OpenGL: AMD, AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 19.1.7, DRM 3.59, 6.11.11-valve12-1-neptune-611-g517a46b477e1), 4.6 (Compatibility Profile) Mesa 25.0.5 (git-a89e404408)
Date: May 7 2025 04:22:22
Boost: 1.88.0
OCC: 7.9.0
Curl: 8.13.0
ngspice: 44.2
Compiler: GCC 14.2.0 with C++ ABI 1019
KICAD_IPC_API=ON
Locale:
Lang:
Enc: ANSI_X3.4-1968
Num: 1234.5
Encoded кΩ丈: (sys), D0BACEA9E4B888 (utf8)
Thanks in advance
David
