BGA Pin Trapped under OshPark Design Rules?
Hey everybody!
I’m designing a breakout for this MAX98390 DSP Audio Amp.
It’s a BGA chip with .4mm spacing.
Under OSHPark design rules for 4 layer boards, I can’t put a Via here or get a trace out.
I think I can change the settings to get a Via on this Reset pin but I’m here for advice :slight_smile:
Is there anything I can try to get this E4 - RESET pin routed out from under the chip?
Can I shrink those red circles? I’ve tried but not sure if I should do this.
0.4mm BGA is quite fine pitch. You probably need a better board house.
I have these settings for Kicad’s 4 Layer Board Design Rules, had anybody tried lowering anything with success?
Hoping to stick with Oshpark if possible but who else do you guys recommend as a board house in the USA that would allow micro vias?
Ahh, I may be able to get lucky with this :slight_smile:
Worth a try at least :slight_smile:
Figured out how to do it with Oshpark here.
This will allow me to make some boards and test the circuit for the lowest cost.
That’s a 1mm pitch BGA. Whole different ball game.
If you just want to test, buy the evaluation board. Or get one of these: http://www.proto-advantage.com/store/product_info.php?products_id=4000019
Totally possible with Oshpark.
After searching I came across multiple people working with 0.5mm BGA successfully with using 0.101mm traces.
You can find the Kicad design file for this project and another one:
If you want more examples just search Twitter for “Oshpark BGA”
I got it done:
0.5mm is not 0.4mm. But knock yourself out, it’s your time/money.
It’s already done :slight_smile:
lol you’re just getting started :slight_smile:
Yea, I’ll be sure to post back to let you know how the reflow goes.
Certainly going to need a stainless stencil for this.
0.5mm pitch is the smallest I’ve done so far.
Plenty of other people successfully soldering these on hotplates from what I have seen.
You can also try this:
Ahh Yes, I follow Greg on Twitter :slight_smile:
He does some amazing stuff!
