Better error message needed for new projects on Win10 (because of Defender)
When I tried to create a new project with a new installation, I received an error message that the file I was trying to create does not exist. Naturally, there are not a lot of options for how to proceed at this point. I had a sudden realization (only because this has happened before with other software) to check my notifications, which only periodically appear, and I saw that Windows Defender was blocking write access from KiCad. Once I allowed this access, KiCad created the project.
Perhaps there’s a way to detect if write access is blocked? I suppose the Windows file creation dialog is fairly standard, but if there’s a way to customize it to suggest disabling any programs that will block file creation, that would probably help a subset of users.
Cheers!
I have never seen that, I think, but we definitely need some more documentation about this or some other way to understand the underlying issue some more.
Where were you trying to save to?
I’d like to add that a similar issue occurs with BitDefender. Its a really annoying feature of BitDefender that tries to stop against Ransomware when it detects an application trying to edit files.
For BitDefender I just disabled “Ransomware Remediation” and that worked. Alternatively you can add KiCad to its list of exceptions, but you need to add every *.exe in the KiCad \bin folder that might write to files.
