I have generated a schematic by cutting and pasting from another and duplicating the results. Everything looks to be properly “assigned” but when I click the “Fill in symbol designators” I get several messages for example "Error: Duplicate items #PWR7A ".
Looking at the GNDs with Edit I can see that these values are assigned but not displayed, and are, of course duplicated, with my copies. The obvious corrections are
re-designate the whole schematic. This is not a good option as I want to keep the other designators as is
go in “by hand” and change each ground. (that would take a lot of beer!)
Is there a better way to do this (or am I letting “prefect” get in the way of “good enough”)
On a more general sense, I am not sure what your end goal is.
You have a hierarchical design and “Amplfiers1” seems to be identical to “Amplifiers2”, but they are different schematic sheets. One of the powerful features in KiCad is that you can use multiple instances of a hierarcical sub sheet.
Paul–nothing special with the end goal–just 4 duplicates of the same driver circuit with different references on the parts of course. I think you are indicating a better way to do this–looking thru the manual I don’t see it.
fritz
(PS-manually updating all the grounds would take a long time–something I do in the late evening with a few beers)
When you create a hierarchical sheet symbol, it asks you for a file name.
In that box just enter the file name of an already existing sheet.
This surely is in the manual, but it’s such a small thing that it’s easy to overlook.
So in your case, use a very simple sheet with just one of the amplifiers, and make 4 copies of it.
I used Duplicate [Ctrl + D] from the popup menu in the example below.
A big advantage of this approach is that our sub circuits will also be the same.
It also enables working with the Replicate Layout action plugin in KiCad.
You may have to mentally adjust because you have less control over the Reference Designators, but that is a small price well worth paying in my opinion.
Thanks Paul, you put a lot of work into this post. I see the hierarchical sheet material in the document–apparently you have to click help from the eeschema program (not the startup menu).
A lot to learn but the new KiCad has a lot of good things and works very well for my purposes.
Fritz
