Is this the intended behavior?
When a polygon is locked in the Footprint and I want to edit it anyway. I enable the possibility to select that object and then I select it to edit it but its corners do not appear.
If I click m
to move it, a popup appears asking me if I want to ignore the lock which is ok.
But I believe it could show me the corners allowing the edition even if the shape is locked, and if I drag the corner it could show me the popup to ignore the lock too, right?
