I’m building a simple board powered by a CR2032 coin cell battery so, after placing the 3V0 and GND power symbols, I’ll need one for the battery or battery holder to associate to a custom footprint. Should I use a battery symbol or place an ordinary connector symbol?
There’s no “should” here, you can choose. KiCad library seems to have generic Battery symbols. You have to attach a footprint anyways. A battery symbol is of course more descriptive and accurate.
Thanks!
Using a battery symbol in the schematic is more “expressive” I guess, since I’m saying how I’ll power the board. Nonetheless the part that needs to be on the board is not a battery but a battery holder with is footprint so… I was wondering what’s the best approach here.
How often the battery is directly connected to the board, without a holder? I believe the battery symbol is usually used for some kind of holder or connector where the battery is attached to.
It took me a bit of practice to realise how flexible Kicad’s separation of symbol from footprint is. A lot of external components can be represented as a connector and the footprint chosen later. So in your shoes I would put a 2 pole connector then assign it a cell holder footprint.
I suppose you could then connect a battery symbol for accuracy but really would you represent every power source in the schematic? One has to delimit the boundary somewhere.
I never before gave it much thought:
Then there is this:
Not being a University papered engineer, I have learned a lot of real world engineering by simple osmosis of working on a lot of different electronic systems.
If the power source/battery is on-board, then use the battery Symbol with the battery holder Footprint.
I went for the battery symbol and a custom footprint in the end.
Thanks for helping!
I would use at my schematic 2 symbols:
- battery holder connected to other elements,
- battery itself - simple circle with no pads.
At PCB I would put one footprint on another.
Thanks to that I will get the correct BOM containing both elements.
