I need to create a mixed part, with an N-MOS and a P-MOS in the same package.
I guess the easy way is creating just a block with pins, but I’d prefer having it as a two units part, each selectable and placeable where I need in schematic.
Now, I can draw everything from scratch, following the guide (as units not interchangeable), but what if I want to copy the two existing symbols in devices.lib?
I tried loading an N-MOS and saving it to a new library, then updated it as a 2 units one, and switched to units not interchangeable … but it didn’t work: it let me change pins for the two units, but the symbol kept staying shared by the two units!
Looks (to me) like an horrible mess: has anybody ever reused parts this way? It’s just me not finding the right controls to do it?
You could try to use a text editor and editing the symbol entry in the lib directly.
Example:
# LED-dual_red/grn_LSGT676_PLCC4
DEF LED-dual_red/grn_LSGT676_PLCC4 D 0 0 N Y 2 L N
F0 “D” -100 0 50 V V C CNN
F1 “LED-dual_red/grn_LSGT676_PLCC4” 185 0 50 V V C CNN
F2 “LEDs:PLCC-4” 0 0 10 H I C CNN
F3 “" 0 0 10 H I C CNN
F4 "” 0 0 10 H I C CNN “Manf#”
F5 “_” 0 0 10 H I C CNN “Manf”
DRAW
T 0 100 -50 31 0 1 0 red Normal 0 C C
T 0 100 -50 31 0 2 0 grn Normal 0 C C
P 2 0 1 15 50 -45 -50 -45 N
P 2 0 1 0 50 5 110 25 N
P 2 0 1 0 60 -25 120 -5 N
P 4 0 1 10 0 -35 -50 45 50 45 0 -35 N
P 4 0 1 0 110 25 90 10 85 25 110 25 F
P 4 0 1 0 120 -5 100 -20 95 -5 120 -5 F
X ~ Aa 0 50 4 D 50 50 1 1 P
X ~ Ca 0 -50 12 U 50 50 1 1 P
X ~ Ab 0 50 4 D 50 50 2 1 P
X ~ Cb 0 -50 4 U 50 50 2 1 P
ENDDRAW
ENDDEF
See the bold numbers?
That’s how KiCAD depicts what unit the object (text, lines, cricle, pin, etc) belongs to: 1=A, 2=B, 3=C, … 0=common to all units.
You could copy both symbols into one via text editor… modify the numbers and with a bit of luck and determination get what you want…
At least that’s a way to get both symbols into one (without much redrawing or whatever) as copying this kind of content doesn’t work inside EEschema yet afaik).
Alternatively (if you want/can redraw) right clicking on lines/circles will allow you to deselect the ‘common to all units’ option, so you can have different symbols for each unit.
[EDIT]
PS: the italic number in the DEF line depicts the unit count. Usually this is just 1, but for multi-symbol parts this is how many units you have.
Gosh… That’s exacted what I tried to avoid: I’ve already peeked in the .lib file with a text editor…
I just hoped I was missing the proper mouse action to do it
Well, afaik KiCAD is missing a copy function for stuff like this (surely will come at some point, but don’t hold your breath), so if you don’t want to redraw you have to do it outside of KiCAD. Sorry.
It’s not that hard actually… just taking all the P & X lines from each symbol, replacing the numbers and moving them into either one of the symbols… restart kicad (or reload libs = preferences/configure libs) and you’re there.
Ah, and I think the DEF line needs adjustment as well… 3rd position from the right depicts unit count I think.
PS:
Try and have a go at it… if you don’t get anywhere in next 12 hours… load the 2 symbols in question into a custom lib and either drop me a pm with them or link them here. I’ll get it done.
Now I gotta hit the bed.
Night
Thanks for help, I made it – editing text in .lib file.
Can be useful for someone else: as text editor I used Notepad++, that has a column selection mode (with Alt + mouse click for selection). This comes in handy, since all the P lines copied have already a single column of ‘0’ instances to change, so if you column select and press ‘1’ or ‘2’ just once, they’re all updated in one go.
Library editor has a tools on the right toolbar: Export current drawing and Import current drawing. This way you can copy graphics from one symbol to another, but not between units.
However, this restriction can be overcome, by reasonably moving symbol anchor and editing properties of the graphic items.
Each graphics item of the symbol drawing has its own properties. You can chose if it will be shared for all units or not. For example. The P-MOS and N-MOS differs by the direction of the arrow. So for all graphics item you can keep checked Share for all units except the arrow body where you should uncheck this option. This way the only thing to redraw in the second unit is the arrow body.
That’s fair. It’s just that in my case I also wanted NMOS source to be picked pointing down (toward GND/VSS, tipically) and PMOS source pointing up, where a VCC/VDD line is tipically hanging, then I had them to flip over.
