I can’t recreate with a very simple version (no *imported fancy curves) on 7.0.5 on Mac OS. Possible that the issue is specific to the 7.99 nightly version or specific to your choice of curve causing some sort of rounding error.
My uninformed guess would be rounding error, so you could go ahead and open up a gitlab ticket (KiCad > About KiCad > Report Bug) and attach the full project. If the project can’t be made public, there is an option for confidential reporting where only the developers can access your files.
Thank you for your reply. The rounding was made with an arc+lines converted to a zone, becaue i did not find a way to create a really round shape otherwise (the circular zone plugin does not seem to work at all for me).
I think you’re quite on the right track. I tried it with a simpler shape, even sharing edges… works.
Will post a bug. I was just wondering, if it is me… ord the program. Been posting some bugs lately
I’m curious about the arc+lines converted to zone though, since I created my little “pie slice” shape with that same technique. Maybe the full 90º + straight lines works differently?
Ah… the auto close bot is very unhappy with this issue in particular If I remember correctly, it is something like the “build settings” section being empty on new nightly builds that causes the bot to fail. If you want, you can use my 7.0.5 version info in that issue to be done with it. (I can’t quickly find the issue/forum post that explained the bot’s problem, sorry)
