Thank you John. I still hope for the future, an increase of viable programmers that can help in this direction. Already great steps ahead have being done. This is another important milestone, in case.
[quote=“tormyvancool, post:85, topic:30441, full:true”]
Although the very last version of FreeRouter suffers of more issue than the previous one and I still use the previous not because I’m “sticked to the past, like a mussel on the sea rocks”, but because it has not the issue I detected and I was not able to make it works properly…
[/quote]
Thank you for the info you provided? Can you point out exactly which Freerouter version you have find out to work best? I ask because there seems to be many different versions/forks available in many different locations and it’s little confusing to try to figure out what version to try out with Kicad.
I remember once trying out some older version of Freerouter but I was at that time just learning the routing and ended up doing everything manually. But I definetly believe that there are many tasks where some interactive autorouting could help my work.
I use the previous version since with the new one I got more quirks. In some cases even not any routing. Perhaps some settings should be changed but I didn’t go deep into it.
Something strange with the installer
My current version 1.4.4
I want to install the 1.4.5.1 and here below you see the result.
I had to remove the old one to install the new. I think it’s a glitch of the installer
Importing and exporting to and from a autorouter is very interesting. Is there something for the autorouter which is in old Mentor Pads CAD. Then we could open the work in Pads and use its better editing tools.
Guys I think I have been misunderstood here - I am not advocating Kicad implement an Autorouter (far from it). When you take the time to learn what you’re doing you don’t need one
it depends on what you are doing. Do not fall down in the error to consider that ppl is doing things with the complexity you are sued to.
Many ones have much more complexities to achive, and without a valid autorouter, it’s just impossible or not profitable.
Just avoid any excuse to avoid to think to an autorouter. Drop the mentality “can’t do it”, justified by sophisms.
In “it’s not useful for the KiCad project to put existing developer resources into a new autorouter instead of other important features”, where exactly is the “can’t do it” mentality and/or sophism?
That doesn’t work as a universal statement, but is a real argument as far as we are talking about majority of the people who want an autorouter, considering what we know about the state of autorouting in general. If, say, 1% of the users who already know how to route would actually benefit from an advanced autorouter, it doesn’t yet justify the effort.
