something I miss from eagle is that I have to save the netlist then update the pcb from the netlist
while this was automatic in eagle
is there a shortcut to make the process less painfull
thanks
Phil
thanks
Phil
You don’t need to do that, there is a button “Update PCB from Schematic” at the top in pcbnew. No need to make a netlist when you don’t need it for something else.
it does not work unless I generate the net list
apparently it works, my bad
