hello. I have a large bitmap logo (like 2x3 inches) that I want to put onto the back of a PCB and it spans over multiple plated through-holes. Is there some way I can tell KiCad to automatically remove the parts of that silkscreened image that go over solder pads?
when plotting you can select “subtract soldermask from silkscreen” that should do the trick
Yes that worked thank you very much!
