I am joining of the secondary to the input of a full wave bridge and then running the -ve to the GND line connecting the voltage regulator and the associated capacitors.
All is good joining the output of the transformer to the AC input of the bridge but when I run the -ve from the the bridge across the one of the AC lines KiCAD puts a junction mark to join the -ve to the AC line.
I delete it but I add other components and then there I come back to the bridge here is the junction mark again
There is no “automatic” junction setting that I can find. Help please?
One thing which comes to mind is that if there’s a symbol pin end and you draw a wire over it, the wire is connected to the pin automatically with a junction.
This is your problem @Graham1904.
If you draw a wire over a wire to pin connection, a junction will automatically be placed. You need to move the vertical wire from the -ve. pin slightly to the left so it does not cross the end of the pin 10 of the transformer.
