Hi ,
I was wondering is there any setting or feature in Kicad which automates the track width depending upon the space available (that is if you are passing between two pads reduce the width , and then increase the width automatically to a bigger size once you are out of constraint zone). This reduces the chance of PCB track failure when PCBs are homemade for prototype (may be using toner transfer method). Example is given in below picture which was done manually by adjusting (maximizing and minimizing) the width depending upon the space available. Thanks.
Using Application: Pcbnew
Version: (5.1.5)-3, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
