I wanted to delete the posts below, upon request of all participants, but it turns out my superpowers are not as great as I thought. I can not delete posts created by others, but I can split it of, and I’ll attempt to make this thread unlisted. Just experimenting a bit with my superpowers.
@teletypeguy, stay on theme and save the rest for other channels. Just my advice.
What sort of advice is that?
A MISO pin is not a simple output and it should not be defined as such. SPI is a shared bus and slaves should tri-state their outputs.
But I don’t want to get involved into a pissing contest, so show (at least a part) of the actual schematic and the part numbers of the IC’s that this is about.
Your power pins are defined as outputs ???
Where did you get such schematic symbols?
Jeez, don’t jump down my throat here, I’m the good guy, OK? That remark referred to an inappropriate comment from teletypeguy, which he/she has now deleted.
Leaving me looking like an idiot. Thanks for nothing, teletypeguy.
Well, I’ve learned my lesson: everything I post from now on will include relevant quotes from the original post. Then I won’t land in the “switch-and-bait” trap again (read: post-and-delete/edit).
Actions like that break the conversation, and make it impossible to follow a thread, and it’s therefore generally not recommended.
It’s easy to draw the wrong conclusions from false assumptions, if you don’t recognize them as such.
@teletypeguy@ML9104
I have superpowers and can delete the whole derailment in this thread. Are you both ok with me doing so?
