Atlc - Arbitrary Transmission Line Calculator (for transmission lines and directional couplers)
This question is not about KiCad but about atlc, an old software that can calculate arbitrary geometries for transmission lines. I am aware of the calculator that is shipped with KiCad, however it has too few geometries and many times I don’t find the ones I need (e.g. a coupled microstrip coplanar without ground plane). I found atlc just now, which looks promising as you simply draw the geometry and get the results. However, I cannot compile it. I know this question is not about KiCad, but if atlc works it would be interesting to try to incorporate it in the impedance calculator of KiCad. Also, I don’t know where else to ask for help about atlc. So, if anyone is willing to give it a try, let me know.
What I did is this:
  1. Downloaded the source code.
  2. Extracted files from the compressed file.
  3. Run ./configure.
  4. Run make.
I get the error /usr/bin/ld: atlc-swap_conductor_voltages.o:/home/me/Downloads/atlc-4.6.1/src/swap_conductor_voltages.c:39: multiple definition of oddity’; atlc-atlc.o:/home/me/Downloads/atlc-4.6.1/src/atlc.c:71: first defined here`. I am in Fedora 41.
Not sure why you expect anyone here to know . . . have you tried contacting the author ?
https://atlc.sourceforge.net/contact.html
You would be better using mdtlc, similarly out of the arc but works very well and has binaries available
If you had looked closer at the Sourceforge site, you would have seen two things:
  1. The source was last updated 10 years ago, so even if you get it to work, don’t expect support.
  2. There is a ticket number 2 which reports exactly the same problem you encountered, and provides the solution. But also see 1.
Thanks for pointing that out. This solved the problem. Now atlc is working. In case someone is interested, I created this Git repo with the bug fixed.
Easy and free simulation of arbitrary transmission lines
I made a Python module that allows to run simulations with atlc directly from Inkscape, as detailed here, which I think is very convenient given its popularity, flexibility and ease of use. This, together with a working version of atlc and installation instructions (for Linux) is available in this repo. Feel free to give it a try.
Example
Dr Kirkby seems to have moved on and left his university position.
Building ten plus year old code on a modern compiler is always going to find errors.
