Kicad 5.1.5
I have a multidigit LED DIP display where the pins are not centered within the footprint. In other words the X distance between the leftmost pin to the edge is not the same as the distance between the rightmost pin and the other edge.
At the moment only one X offset from the pads can be specified for both sides. So I’ve used the greater of the two offsets, but it means the footprint takes up more space that the part really does. Here’s the slightly oversized footprint I’m using at the moment.
Any idea how to handle this short of modifying the footprint wizard to accept two offsets? Not a showstopper, I have enough space on the board.
