Is anyone else having issues assigning net net classes in PCBnew? The dropdown menus in Board Setup > Design Rules > Net Classes > Assign Net Class are giving me issues, in that I am unable to select any of their options when they drop down and immediately hide themselves. I have demonstrated the issue in a screen capture here: https://youtu.be/NIl5qXHjatk
Best,
-John
Include your full version info from help->about kicad->copy version info
It looks like my video didn’t work, as windows didn’t record the pop-up where the error occurs. In any case, it occurs in this window:
When I click on the “New net class” dropdown on the bottom, the dropdown disappears before I can click anything. I am running this on Windows 10.
eelik
August 29, 2019, 8:10am
5
It has happened to me, and seems to happen right now. You should be able to change the item with keyboard up/down arrows after you have once clicked on it with the mouse.
eelik
August 29, 2019, 8:12am
7
Rene means this:
Here’s my version info:
Application: ModEdit
Version: (5.1.4-26-gdcd31f570)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
I’m using Win7 but I believe this happened on Win10, too.
Aha, thanks! Here’s the version info:
Application: KiCad
Version: (5.1.4)-1, release build
wxWidgets 3.0.4
Boost: 1.68.0
Curl: 7.61.1
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
The arrow key workaround seems to work for now, so thanks for that @eelik ! I was able to use this feature properly in past builds of KiCAD, so it looks like this may have been broken in the most recent build.
system
Closed
November 27, 2019, 8:26am
9
