Got rather stuck assigning 3d models in Kicad 8. I’ve been through all the docs. and threads I can find but must be missing something.
Problem:
I have imported my Eagle .lbr file of JLPCB symbols and footprints and migrated it to Kicad format. This seems to have worked ok.
I don’t have 3D models so I go to “properties” for a basic 0603 SMD resistor and choose the correct 3d model from the built-in Kicad 3d models. Seems ok… so far.
in my test I put a 0603 on a board and set the 3d model. I tried duplicating the resistor on the schematic then going g to the PCB. here, after updating the duplicated resistor had lost its 3d model .
I played around and it just got stranger… 3d paths in component properties I had set had disappeared for some other resistors I added , yet some resistors had the path and showed the model in the 3d viewer.,
Others were missing. Anyway, totally confused now LOL!
So is there a “correct” way to set a 3d model to a library part so it stays permanently in the library, in the PCB and if I duplicate a part?
TIA
