I’m designing a PCB from the Arduino template available in the Kicad library.
I used eeschema for the schematic: no issue.
The problem appear with PCBNew: the connector from the Arduino template couldn’t be connected to the other components. (even if the ratsnest indicate the connection with the connector pin…).
I tried to change the layer (cpt <=> copper and vice versa…) but without result…
Someone could help me?
Thank you in advance for your support!
PS: In attachment screenshoot: the detail view is more focus on the issue: track “DIN” can’t be connected to the PIN 6 of the connector.
I have what is basically a “guess” could your arduino template be off grid enough to not allow the connection with on grid traces?
BTW I had trouble with an arduino pro mini library template (width was wrong, i probably selected the wrong template , I was somewhat green at that time). I ended up making one for my own library. It was not that difficult, good experience, and now I’m sure it suits my needs.
