I would hope to do some work using the Arduino MKR ZERO controller and use KiCad to draw the schematic. I looked in the KiCad library but didnt find anything relating to Arduino.
If a CAD symbol/model did exist, could it be imported to KiCad ?
There is no symbol for the Arduino MKR ZERO, but there are many others. I don’t know whether you could load the closest match from the library and modify it to suit your requirements.
It’s really quite simple to create your own symbols. If you do it yourself you will at least be confident that it is correct.
Try this one from SnapEDA.
As with anyu import from a 3rd party, you will need to verify the part.
Contains many Arduino symbols & footprints, including the MKR Zero. Installation instructions included in the link.
