Hi All,
Is there any way to disable interactive routing in OpenGL mode, and work with fully manual mode? Or the only way is to switch back to Legacy.
Switch it to “Highlight collision” mode. This can be done in the dialog found under preferences->interactive router. (Might have been moved in recent nightlies)
Another way to open this setup dialog is by pressing “e” while in routing mode.
You might need to exit routing mode and re enter it to get the changes active.
Thanks
Works as needed.
