What is the canonical way of setting the antipad size on a non-functional layer? In particular, I have an 8-layer board, where the high-speed (10 GHz) signals run on the outer layers, which are connected by vias. Now, for reasons related to impedance control, I’ve removed the pads on all non-functional layers like so:
The problem is that the antipads are now defined by the diameter of the via, and not anything else. (This can be seen in the fact that the hole on the green layer, which is the first inner layer, is smaller than the hole on the red layer, which is the top layer.) However, I’d like to be able to control the antipad size. (Some even recommend elongated antipads.) What is the correct way of doing this in KiCAD?
