KiCad 4.0.7 has a “feature” of adding libraries directly from github when using “Add Library with Wizard”, but if I’m trying to use KiCad part repos from some manufacturers (like SparkFun repo here : https://github.com/sparkfun/SparkFun-KiCad-Libraries) it doesn’t see any.
So questions are:
what should be structure of repo, to make it recognizable by KiCad?
I don see “Add library with Wizard” in KiCad 5 builds. Is this feature planned to be deprecated?
Using on demand github download is no longer the suggested way to add libraries. I would suggest you download (or clone) the repo locally and add the local repos using the library manager (or wizard)
Drawbacks of on demand libs:
no control over the used version. (Always git master)
every library must be in its own repo (hard to maintain, makes releasing specific versions a lot harder)
a lot of unnecessary internet traffic. (The plugin downloads full libs as zip. The local cache is deleted every time kicad is closed.)
it relies on the github API. There is no guarantee that it stays unchanged for the coming years. (It is not meant for such a use case. )
