Annotation of a duplicate sheet V6.0
Firstly, congratulations are in order on V6, it is not Altium, but it is very much getting there.
So I have a hierarchical design in which I first drew a sheet containing some parts having multiple sub components (an '084 quad opamp), annotated it then fixed the annotation up such that the ABCD identical sub components made sense for the design (The default had split nearby functionality across multiple packages), all good so far.
I then duplicated the sheet to produce several other identical channels.
Problem, upon running annotation the annotation did not respect the groupings of sub parts I had defined in the original sheet.
Is there any way to fix this other then manually going in and shuffling opamps around on the schematic?
It matters because replicate layout needs all the sheets to be identical, which they are not if the sub components are carved up among the packages differently.
You can go in and fix it manually, it is just annoying.
