Can someone explain how this works in V6 , I created the list of alternative pins in the symbol editor but when I go into the properties of the symbol on the schematic , and hit "alternative Pin assignments ", the dialog doesn’t show any alterative pins
Did you update the schematic symbol from the library? (This would be necessary assuming you added the alternative pins in the symbol editor after placing the symbol in the schematic.)
