Is there a way I can have the push shove router lay out 15 mil traces unless it needs to go to 6-9 ish to sneak between pins/pads while respecting minimum spacing?
This is called “automatic neckdown” and is a feature we want to add in the future, but it doesn’t exist today.
Thanks. I guess I could route it using a smaller track with then expand the rest of the track.
It depends on what you are looking for. I have run into this with escape routing under BGAs. With the 5.99 Nightlies, there is now a more sophisticated area-base DRC rule engine that can handle this I believe.
With 5.1 and prior here was my work around (which is a bit of a pain):
- Set the netclass rules smaller specs
- Route out under the BGA to the edges
- Run the DRC
- Set the netclass rules larger specs
- Route out route the rest
- Run the DRC, ignoring the flags that were already checked.
The quickest way to do it manually is:
Pcbnew / File / Board Setup / Design Rules / Tracks & Vias / Pre-defined track and via dimenstions
Then add some track widths you want to use (so for example 15mil and 8 mil in your case), and then after that you can switch with hot keys between the thicker and the narrower track in that list (you can have multiple widths).
