My workflow is to create a schematic in eeschema (8.0.5 currently) and export a Cadence Allegro netlist which is used by a PCB Design Bureau that uses Allegro. The PCB design bureau has its own library of footprints each of which has a PSM file and a unique reference number - eg X1234.PSM
The documentation for the Allegro Exporter at David Schneider / KiCad-Allegro interop · GitLab suggests that:
… the main enabling feature is that your parts should have a footprint filter or footprint field that has the name of a .psm (without extension) in your Allegro site’s psmpath. Additional entries in the footprint filter list will create a
ALT_SYMBOLSproperty on the part. Any non-glob filter will be used, so you should be able to create a hybrid pcbnew/Allegro symbol library – you’ll just have to make footprints for both backends.
So in my Library I select a part and change the footprint filter to X1234
Then in the schematic, I update the part(s) from the library and run the Allegro Netlister.
If I search the output netlist X1234 does not appear in any of the parts.
Based on my understanding, it doesn’t seem to work…
Since I am not using KiCAD for Layout, if I just change the footprint reference for the part to X1234 then that does appear in the netlist, but prefixed with the component value:
!1k_x1234!1K;,
R101
I’m no expert in Allegro, so I am wondering if this is enough to work?
