@aisler I’m trying to upload a board design with MPNs populated as described in Transfer custom Fields from Schematic to PCBnew? - #12 by eelik
Despite populating a AISLER_MPN field it doesn’t populate on the Aisler parts page.
Checking the contents of the .kicad_pcb file show the property has transferred OK:
(footprint "Capacitor_THT:C_Rect_L18.0mm_W6.0mm_P15.00mm_FKS3_FKP3" (layer
"F.Cu")
(tedit 5AE50EF0) (tstamp 00000000-0000-0000-0000-0000608e58c9)
(at 221.742 175.26 180)
(descr "C, Rect series, Radial, pin pitch=15.00mm, ,
length*width=18*6mm^2, Capacitor, http://www.wima.com/EN/WIMA_FKS_3.pdf")
(tags "C Rect series Radial pin pitch 15.00mm length 18mm width 6mm
Capacitor")
(property "AISLER_MPN" "R463I315040H2M")
Any ideas?
Tristan
I think (but not sure) Aisler’s latest code is looking for mpn
, not AISLER_MPN
based on https://twitter.com/PatrickAachen/status/1479078099887263745 - not sure if capitalization matters; MPN
might work too.
Thanks - have tried all 3.
"F.Cu")
Capacitor")
(property "MPN" "R463I315040H2M")
(property "Sheetfile" "xxxxxxxx.kicad_sch")
(property "Sheetname" "")
(property "mpn" "R463I315040H2M")
(path "/00000000-0000-0000-0000-000060889620")
(attr through_hole)
(fp_text reference "C101" (at 7.5 -4.25 180) (layer "F.SilkS")
(effects (font (size 1 1) (thickness 0.15)))
(tstamp 975b065a-4fee-4d11-9f2f-b1d40a3629cb)
Hopefully Patrick will see this or my tweet. Would be a really useful tool to have working.
The new push tool only seems to transfer “mpn” from reading this: https://github.com/AislerHQ/PushForKiCad/search?q=mpn
[115] 'side': layer,
[116] 'designator': f.GetReference(),
[117] 'mpn': f.GetProperty('mpn'),
I’ve tried direct upload of the .kicad_pcb file and the push tool with MPN, mpn and AISLER_MPN. Nothing seems to pull the value through.
@aisler Patrick - this is a strange one. Is there a limit to the BoM size / number of parts on your side?
I tried again with a simple board of 5 or 6 components - things worked as expected. Items appear to populate / get prices and so on.
When I try with a larger board (202 items in the BoM, 3.2Mb .kicad_pcb file) the MPNs aren’t coming through.
eelik
January 7, 2022, 9:47pm
7
A recent commit allows mpn, MPN, Mpn and AISLER_MPN, see https://github.com/AislerHQ/PushForKiCad/commit/defea7d69c8f10f578ac6f45aa4135af190a86c0 .
EDIT: the uploading code was also changed on Jan 5, make sure you have the latest code.
Thanks, I saw that earlier today.
I think my issue is with the number of components or the size of the board file. I had thought there may be a hard-coded limit of 200 somewhere in their code - so tried excluding items from the BoM within KiCAD. But that doesn’t get respected in the Aisler system. I’ll try deleting components and see if there’s a point when the auto system starts working again…
aisler
January 8, 2022, 1:47pm
9
Patrick from AISLER here. The part import is done asynchronous to the general import however there is no progress indicator which is, I have to admit, a bad combination. So if you wait for a few minutes after import all parts should pop up. We will work on this the next days.
Thanks Patrick - my bad. Patience is a virtue etc.
I left it and yes, after a few minutes the parts started populating. Thanks for the response.
system
Closed
April 8, 2022, 7:25pm
11
