I just update my Ki-Cad from 4.0.5 to presumably 4.0.7. after i did the upgrade and i restarted the computer and ran Kicad i checked the software its still saying version 4.0.5. is there anything special about the update , did i miss anything?
After the download was completed , i double clicked the file
kicad-4.0.7-X86_64.exe
At the beginning of the installation there was message saying an older
version was found it will be removed and the newer version will be
installed
I hope will give you some clues
Just for your information, your contact details are now publicly readable on the kicad forum. You might want to remove them. (The mail was sent by the forum software. I did not sent a private mail.)
As i am a linux user not a windows user i can not really tell how this should work.
Many of us have upgraded 4.0.x through to 4.0.7 by simply overwriting and it works.
I am not clear from the first post if the 4.0.5 was a 64 or 32 bit version. It shows that the PC OS is 64 bit.
Can you check to see if you have a kicad folder under C:\Program Files (x86)\
