After moving component to back it disappears
Kicad 5.2.2 (Windows 10)
I am using a test point pad from the Kicad library and I need to place them on the bottom of the PCB, for PoGo pins. I select Move for a test point and then enter “F”. The pad appears to change to the Bottom layer (it is green), however, when I select another component the one I moved to the bottom disappears. There appears to be no way to get it visible again.
If I open the 3D viewer I see the pad on the bottom layer.
Is this a known issue or how can I resolve it?
Sid
Check the visibility options on the right side. Both for layers and items.
Top and bottom layers are visible, I see all my traces perfectly,
Sid
footprint features visibility can be controlled separately. Switch the layers sidebar to item mode and check there.
Thank you, footprints back was not visible.
Sid
