Hello all,
I am new on this forum and I hope I will find a solution.
I have downloaded file on library at this link:
http://smisioto.no-ip.org/elettronica/kicad/kicad-en.htm
I would like to use the Kicad library "A/V Connectors (28/09/2014) " most especially RCA connectors however, I can not see the 3D model on CvPcb or Pcbnew.I can load the module “RCA” and see that on CvPcb but it is not possible to see the 3d view.
For information I use :KiCad_stable-2013.07.07-BZR4022_Win_full_version.exeWings 3D 1.5.3
So, I downloaded the 2 zip files:
- mod_conn_av.zip (Footprints)
- 3d_conn_av.zip (3D modules)
After dezipped
I put the folder “mod_conn_av” in the folder “C:\Program Files\KiCad\share\modules”
I have loaded the files with CvPcb and I can select the module RCA black red for example. I can see also the module view of the RCA.
However if I open for example the file “rca_black.wings” … wonderfull … I
can see the 3D view but it is not still working in CvPcb.
Concerning 3D, I try this :
folder “3d_conn_av” in the folder “C:\Program Files\KiCad\share\modules\packages3d”
folder “conn_av” in the folder “C:\Program Files\KiCad\share\modules\packages3d”
Could you please tell me how can I do in order to well see the 3D view in Kicad ? I will appreciate if you could help me.
Thank you in advance for your feedback
Best Regards
