Addressing issues originating from the ground plane through the application of a filled zone."
i used add filled zone for common ground plane .but it look unconnected after applying filled zone
reasons I have seen which cause a filled zone to be unconnected (or only looking like unconnected):
  • zone display mode is set to “show only zone boundaries”. View–>Drawing mode–>Draw zone
  • zone is not recalculated after drawing the zone: Edit–>Fill all zones
  • zone has not the correct netname assigned (to check: click==select zone, look into statusbar for net-information. To change the assigned netname: open zones properties dialog
  • zone clearance value is much too large (so no copper can’t be generated without violating the clearance value)
  • zone is divided into multiple parts, where some parts are not connected to others. Such islands happen due to tracks cutting the zone in pieces.
