Addon to push parts to DigiKey myLists
This addon helps you collect parts in your KiCad schematic file and push them to Digi-Key myLists.
With your BOM in myLists you can calculate attrition, find and assign alternates, add assembly counts, and more.
Installation
  • Download the addon from latest release
  • Open KiCad, select KiCad Plugin and Content Manager, click Install from File...
  • Select the downloaded .zip file in step 1, click Open
How to Push your BOM to DigiKey
  • Open PCB Editor, click the Push to Digi-Key myLists icon on the toolbar
  • In the dialog that opens, verify the parts list and modify the list name if desired, then press the Create DigiKey List button
  • Parts will be pushed to Digi-Key myLists
Plugin installed Plugin in PCB editor Parts pushed to Digi-Key myLists
Is there a step missing in these instructions? I’m thinking that it needs to somehow log in to my account on DigiKey. Perhaps it’s going to invoke a web browser?
I’m running this on Linux, using Brave as my default browser, and I just get the progress bar saying it’s ā€œUploading your BOMā€. The progress bar makes it just under halfway and then nothing. It just hangs there; forever as far as I’ve waited so far.
Oh, I’m also using KiCad 6.0.11 since KiCad 7 still isn’t out for Debian Linux. Maybe this doesn’t work on the old KiCad.
Hi @David_Bridgham - Login is not needed. The plugin opens a guest myList at DigiKey. You are correct that the plugin opens the browser. Could you try with another browser to see if the issue persists?
KiCad 6 is supported with this plugin.
I’ve tried Firefox, Firefox-ESR, and Chromium and I’m now getting a pop-up error message:
/usr/lib/python3/dist-packages/urllib3/connectionpool.py:1048: InsecureRequestWarning: Unverified HTTPS request is being made to host ā€˜www.digikey.com’. Adding certificate verification is strongly advised. See: Advanced Usage - urllib3 1.26.15 documentation
warnings.warn(
In fact, I now get this message when I switch back to Brave as well.
After a timeout, I got more to the error message. Don’t know if it’s helpful, but I’ll quote the whole thing:
warnings.warn(
Exception in thread Thread-7:
Traceback (most recent call last):
File ā€œ/usr/lib/python3.11/threading.pyā€, line 1038, in _bootstrap_inner
self.run()
File ā€œ/home/dab/.local/share/kicad/6.0/3rdparty/plugins/internal_kicad_pushToDigiKeyMyLists/ki_push_thread.pyā€, line 39, in run
print('\nStatus Code: ', r.status_code)
AttributeError: ā€˜NoneType’ object has no attribute ā€˜status_code’
Thanks for the follow-up and the error messaging details! We’ll look into it.
@David_Bridgham, can you try the latest release (v1.01) and see if you still get errors?
I now get this:
The plugin cannot push part data to Digi-Key myLists.
Cannot connect to https://www.digikey.com/mylists/api/thirdparty.
If your computer is behind a proxy system, please contact your administrator.
I am not behind any sort of proxy. The former error message looks like it was more informative if a whole lot more obscure. It’s almost up there with TeX error messages.
I tried tracking down that earlier error message and adding certificate verification as it suggested. I was told that ā€˜certifi’ was already installed so while it might appear more informative, it didn’t get me there.
Another thing I’ve noticed is that when I click on the Icon to send the parts list up to DigiKey, the PCB is marked as ā€˜modified’ so it needs to be saved again. It’s minor but it seems like it oughtn’t do that.
