I have finished my first KICAD project (Schematic, Board, Symbol editor, Footprint editor). In the symbol editor, I have created an additional field under “Symbol Properties” in which the article numbers of our components are entered. I need this article number for the Pick&Place lists. Maybe it’s simple, but at the moment I can’t find a way to output this field under “Fabrication Outputs → Component Placements”. I am wondering if there are already solutions for this and if not, how can I find a solution?
Can anyone help me further? Thank you very much.
In the meantime, one way to do this would be to export both the position file and a BOM (which can be customized) then use an external script to pull data from the BOM in to the placement file.
