I would like to make footprints like this SMP connector. I can create the two SMD pads (rectalnel for the middle conductor, custom for the outer shield, through holes for the vias), but I have a problem figuring out how to set up the pads for the shield. They are all pad number 1, connection to copper zones is set to “solid” for all shield pads, and “use pad convex hull” for the custom pad. However when I connect them to a copper fill, it fills the inside of the shield connector as well, not just the convex hull of the part. As the image shows, both pads are fully connected.
