Add track not complete
I have created module with off-grid pin position. Minimal grid is 0.01mm, but pin is located at i*0.005 mm. I manually entered position by reference when module created. It is a SOT-666 6-pin part, where pins are not the same size.
When select tool is active, my cursor can’t point exactly to the centre of pin (as it is at 0.005mm grid). When I switch to “Add track and via” mode, cursor automaitcally jumps to the centre. I can click the mouse, start the track, but can’t place a breakpoint with mouseclick or via with V button: end of wire keeps moving following my mouse. I think it is because of the off-grid pin position, as lots of other tracks could be placed without any problem previously. This thing happens only at my own-defined modules.
Any idea what to do (out of re-creating the module)?
Sorry for the false alarm: it is not because of the grid settings.
I didn’t notice that a “Errtype 4 : track near pad” shows up for a moment when I try to place the corner.
The pins of the module are closer than the minimal track proximity at my design rules.
(It’s a bit lame that no message appears when placing module with pins against my design rules, no message when start wire with clicking pin, and no message even when driving first two track segments…)
I changed “default clearance” from 0.254 to 0.2mm, and problem gone!!
