I have just down loaded the latest nightly build and in PCB Editor pressing ‘x’ adds a track. When I press ‘w’ to increase the size of the track it does not increase despite the track size drop down menu value increasing. Pressing escape and then x again creates a track of the size in the drop down menu. The same happens for ‘shift x’
Is this a bug?
I do have that icon clicked, but don’t seem to have that menu item.
In the current version (5.1.10) you can still use the ‘w’ key combination to change track size even with it selected. I’m sure in the previous 5.99 nightly this worked as well.
Could it be that you haven’t set a list of default track widths?
Usually I set them on the preferences and using ‘w’ or ‘W’ I can select the width for the track.
