Add testpoint report into jobset file
I’m using KiCAD Testpoints plugin (Package identifier: com.github.TheJigsApp.kicadtestpoints-pcm) and it works very well when running manually from Kicad PCB editor.
On the other hand, I’m using jobset files to generate gerbers, schematics and other outputs.
I can’t see any obvious way of running the plugin from jobset. Is there a way of invoking it from jobset?
If not, is there other way of generating testpoint data via jobset feature?
