I would like to add a rule while creating my differential pair but I don’t know how to do it. I would like that the space between 2 different pairs is 0.76mm but I don’t know how to set that up.
If you have any idea on how I could do it, it would be more than welcome ^^
What I would like to do is to add a rule for inter-pair keep out. I have several SATA, so it is two differential pairs for each and the space between each pair should be at least 0.76mm but I don’t know if it is possible to add this rule.
The width of my pair is ok and the space between each lane of one pair is also good but I now need to fix the space between 2 different pairs if it is possible ^^
With “Differential pair dimensions” I can set my width to 6mil and my trace gap to 8, but is there a way to fix the inter-pair keep_out to 30mil or I have to do it approximately ?
I am not really familiar with it and maybe it is not a big deal to have those 30mil between 2 pairs but I heard it has to be as “clean” as possible ^^
I had the same issue with a layout over a year ago. Differential pair bus, equal length, with a gap requirement. As I recall, I set the differential routing spacing, but then used the main DRC settings to set the gap. I think I then had to change the DRC setting back to the pair spacing to get it to pass DRC. Be warned, this was pre-4.x stable release so I don’t know the behavior is still the same.
I would like to see these feature updates related to the Design Rules:
Differential trace with gap spacing.
DRC by zone/region for BGA escape routing.
Most of the time the fine-pitched BGA region will have different constraints than the rest of the board.
There is also a USB 3.0 interface on this board. In case it’s not known, if you have high-speed controlled impedance traces on your board, you also need to let the board fab house know. Just because you specify 6 mil traces with a gap of 8 mil, they may not come out to the calculated 90 Ohms due to variations on fab process, prepeg thickness used, etc. On my Fab layer, I have a notes sections that calls out the following:
DIFFERENTIAL CHARACTERISTIC IMPEDANCE FOR THE FOLLOWING NETLIST PAIRS SHALL BE 90 OHMS +/-10%:
SSTX+ & SSTX-
STX+ & STX-
SSRX+ & SSRX-
USB_D+ & USB_D-
The board house will generally then come back and tell me they are adjusting the 6/8mil pairs to 5.8/7.5 or something to match their particular process for those traces.
Best in that case is to mark the part you want to address and hit the ‘Quote’ button that appears.
That way the one being quoted also get’s a message - depending on his personal settings.
Another way to get the attention of someone is to start writing an @ , a list will pop up and you can select or keep writing the name of the person - this also will send him a message.
@1.21Gigawatts, I export the IPC-D-356 Netlist File from File -> Fabrication Outputs, and include it in the fab package. In the past, I have had a NOTES section that stated something like:
DIFFERENTIAL CHARACTERISTIC IMPEDANCE FOR ALL TRACE PAIRS WITH 6 MIL WIDTH AND 8 MIL SPACING ON LAYER 1 SHALL BE 90 OHMS +/-10%
But this is more of a pain to keep track of, and if a trace jumps layers it is a pain.
