Hi all,
Im trying to route a PCB and for some reason whenever I press X (route a track) my kicad freezes for a couple seconds. I have a strong PC (RTX 4070 Ti Super) 32 GB RAM etc so I dont think this should be happening on a light to medium sized board. Any advice? When I’m in fallback mode there is no problem.
Kicad Info:
Version: 8.0.6, release build
wxWidgets 3.2.6
FreeType 2.13.2
HarfBuzz 9.0.0
FontConfig 2.14.2
libcurl/8.8.0-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: NVIDIA Corporation, NVIDIA GeForce RTX 4070 Ti SUPER/PCIe/SSE2, 4.6.0 NVIDIA 566.03
Date: Oct 14 2024 01:02:33
Boost: 1.85.0
OCC: 7.8.1
Curl: 8.8.0-DEV
ngspice: 43
Compiler: Visual C++ 1939 without C++ ABI
cheers
dom
jmk
November 22, 2024, 1:06pm
2
Hi, please give OS and Kicad version.
Find them on Kicad > Help > About Kicad > top RH corner Copy then Paste into a forum post.
Thanks for the reply, I edited OP with the requested info. I noticed it also freezes when I’ve completed a track.
jmk
November 22, 2024, 1:12pm
4
Thanks.
I’m not sure of your problem, but I doubt anyone else would give an opinion without that information.
Where did your graphics drive come from ?
installed by default with Windows 11
from the PC vendor
direct from the Nvidia website
Came from nvidia website. Havent had any issues with any other graphics intensive applications.
I think it might be related to my custom DRC rules. Has anyone seen this make a significant impact? Here they are:
(version 1)
# EuroCircuits
# Defined impedance 4 layers, 35um inner copper
# board edge clearance outer copper
(rule EdgeClearance
(constraint edge_clearance (min 0.25mm))
# courtyard 0.1mm exception
(rule CourtyardClearance
(constraint clearance (min 0.1mm))
(condition "A.intersectsCourtyard('*') && A.Type != 'Zone' && B.Type != 'Zone'")
(rule "Allow vias of same net to intersect"
(constraint connection_width (min 0mm))
(condition "A.Type == 'Via' && B.Type == 'Via' && A.Net == B.Net"))
(rule IPI
(constraint hole_clearance (min 0.20mm))
(rule OTW
(layer outer)
(constraint track_width (min 0.1mm))
(rule OTT
(layer outer)
(condition "A.Type == 'Track'")
(rule OPP
(layer outer)
(condition "A.Type == 'Pad' && B.Type == 'Pad'")
(rule OTP
(layer outer)
(condition "A.Type == 'Pad' && B.Type == 'Track'")
# pad to via clearance 0.1mm
(rule Pad2ViaClearance
(condition "A.Type == 'Pad' && B.Type == 'Via'")
(rule ITW
(layer inner)
(constraint track_width (min 0.125mm))
(rule ITT
(layer inner)
(constraint clearance (min 0.125mm))
(rule ITP
(layer inner)
(condition "A.Type == 'Track' && B.Type == 'Pad'")
(rule IPP
(layer inner)
(rule IVV
(layer inner)
(condition "A.Type == 'Via' && B.Type == 'Via'")
(rule IAR
(layer inner)
(condition "A.isPlated()")
(constraint annular_width (min 0.125mm))
(rule RF_width_outer
(layer outer)
(condition "A.NetClass == 'RF'")
(constraint track_width (min 0.185mm) (max 0.185mm))
(rule RF_width_inner
(layer inner)
(constraint track_width (min 0.158mm) (max 0.158mm))
(rule SAI_inner
(layer inner)
(condition "A.NetClass == 'SAI1'")
(constraint track_width (min 0.10mm) (max 0.25mm))
system
Closed
February 20, 2025, 1:33pm
8
