Maybe it’s just me, having missed a memo or two regarding new standards or improved parts.
I was in need of a part I usually try to avoid, a simple trim-pot.
The symbol was easily found (RTRIM, Device:RTRIM with full name) and dropped into the schematic. The symbol looked as expected, but as I wanted to marry it to the other denizens of the schematic, I had to take a break. Cleaning my glasses didn’t help, checking the pin count using my fingers (done twice to be sure…) confirmed the result I found at the beginning.
Two. Two pins.
I’m used to trim-pot’s having three pins, the two ends of the resistive track and the wiper. The symbol editor’s pin table agreed with the count of two passive pins.
OK, on trim-caps and adjustable inductances I’m used to two pins.
So, where can I buy a two-legged trim-pot?
Is it me or the library that could do with an update?
Meanwhile I use R_POT_TRIM, having three pins but looking a bit strange to me.
(I’m working with Windows 10, KiCad Version: (5.1.2)-1, release build, downloaded and installed the 09. May 2019. Neither I nor someone else here admits to editing a library.)
