This is the install.log
**Detecting compiler hash for triplet x64-windows…
– Automatically setting HTTP(S)_PROXY environment variables to “127.0.0.1:10809”.
The following packages will be built and installed:
wxpython[core]:x64-windows → 4.1.1#9 – C:\Users\86131\AppData\Local\vcpkg\registries\git-trees\193a218169b9447eb971c2118c3092b761a57514
Restored 0 package(s) from C:\Users\86131\AppData\Local\vcpkg\archives in 426.4 us. Use --debug to see more details.
Installing 1/1 wxpython:x64-windows…
Building wxpython[core]:x64-windows…
– Installing port from location: C:\Users\86131\AppData\Local\vcpkg\registries\git-trees\193a218169b9447eb971c2118c3092b761a57514
– Using cached wxWidgets-phoenix-7d45ee6abbbc284f34d2ff018c464b65774f4ff3.tar.gz.
– Cleaning sources at F:/vcpkg/buildtrees/wxpython/src/65774f4ff3-9ce5a4ad89.clean. Use --editable to skip cleaning for the packages you specify.
– Extracting source F:/vcpkg/downloads/wxWidgets-phoenix-7d45ee6abbbc284f34d2ff018c464b65774f4ff3.tar.gz
– Using source at F:/vcpkg/buildtrees/wxpython/src/65774f4ff3-9ce5a4ad89.clean
– Using cached wxWidgets-wxWidgets-7ad1bffa875f7a38db58b6069ea3ff0c49c211d2.tar.gz.
– Cleaning sources at F:/vcpkg/buildtrees/wxpython/src/0c49c211d2-fef4512db7.clean. Use --editable to skip cleaning for the packages you specify.
– Extracting source F:/vcpkg/downloads/wxWidgets-wxWidgets-7ad1bffa875f7a38db58b6069ea3ff0c49c211d2.tar.gz
– Using source at F:/vcpkg/buildtrees/wxpython/src/0c49c211d2-fef4512db7.clean
– Using cached msys-gzip-1.11-1-x86_64.pkg.tar.zst.
– Using cached msys-bash-5.1.008-1-x86_64.pkg.tar.zst.
– Using cached msys-diffutils-3.8-2-x86_64.pkg.tar.zst.
– Using cached msys-coreutils-8.32-2-x86_64.pkg.tar.zst.
– Using cached msys-grep-3.0-2-x86_64.pkg.tar.xz.
– Using cached msys-sed-4.8-2-x86_64.pkg.tar.zst.
– Using cached msys-libpcre-8.45-1-x86_64.pkg.tar.zst.
– Using cached msys-gawk-5.1.0-2-x86_64.pkg.tar.zst.
– Using cached msys-mpfr-4.1.0-1-x86_64.pkg.tar.zst.
– Using cached msys-gmp-6.2.1-1-x86_64.pkg.tar.zst.
– Using cached msys-libreadline-8.1.001-1-x86_64.pkg.tar.zst.
– Using cached msys-ncurses-6.2-2-x86_64.pkg.tar.zst.
– Using cached msys-pkg-config-0.29.2-4-x86_64.pkg.tar.zst.
– Using cached msys-make-4.3-3-x86_64.pkg.tar.zst.
– Using cached msys-libintl-0.21-1-x86_64.pkg.tar.zst.
– Using cached msys-libiconv-1.16-2-x86_64.pkg.tar.zst.
– Using cached msys-gcc-libs-11.2.0-3-x86_64.pkg.tar.zst.
– Using cached msys-msys2-runtime-3.2.0-8-x86_64.pkg.tar.zst.
– Using msys root at F:/vcpkg/downloads/tools/msys2/79d5b6b790550399
– Found Python3: F:/kicadsor/kicad/build/x64-Debug/vcpkg_installed/x64-windows/tools/python3/python.exe (found version “3.9.10”) found components: Interpreter
CMake Error at scripts/cmake/vcpkg_execute_build_process.cmake:129 (message):
Command failed: F:/kicadsor/kicad/build/x64-Debug/vcpkg_installed/x64-windows/tools/python3/python.exe -m pip install -r F:/vcpkg/buildtrees/wxpython/src/65774f4ff3-9ce5a4ad89.clean/requirements.txt
Working Directory: F:/vcpkg/buildtrees/wxpython/src/65774f4ff3-9ce5a4ad89.clean
See logs for more information:
F:\vcpkg\buildtrees\wxpython\prepare-requirements–out.log
F:\vcpkg\buildtrees\wxpython\prepare-requirements–err.log
Call Stack (most recent call first):
C:/Users/86131/AppData/Local/vcpkg/registries/git-trees/193a218169b9447eb971c2118c3092b761a57514/portfile.cmake:48 (vcpkg_execute_build_process)
scripts/ports.cmake:147 (include)
error: building wxpython:x64-windows failed with: BUILD_FAILED
Please ensure you’re using the latest port files with git pull
and vcpkg update
Then check for known issues at:
Issues · microsoft/vcpkg · GitHub
You can submit a new issue at:
Sign in to GitHub · GitHub
Include ‘[wxpython] Build error’ in your bug report title, the following version information in your bug description, and attach any relevant failure logs from above.
vcpkg-tool version: 2022-07-21-a0e87e227afb536c62188c11ad029954f28fdb22
vcpkg-scripts version: 0257395b0 2022-07-26 (25 hours ago)
You can also use the prefilled template from F:\kicadsor\kicad\build\x64-Debug\vcpkg_installed\vcpkg\issue_body.md.**
