Hi everyone,
I have a question about edge cuts in PCB Layout Editor. When I try draw any slot or hole in current PCB, it does not cause any problem and completes successfully. But if there are 2 PCB in worksheet and both of them have a slot or hole, the 3D viewer cannot display spots or like someting on the second PCB.
Interestingly, if you make position the second PCB to right side of the first PCB, 3D viewer works without problem. (By the way there is no any problem only right side of first PCB. Other sides not working.)
Is this a rule for only KiCAD or a bug? And Is there any solution about subject?
[KiCAD Version: (5.1.6) - 1 Release Build]
Thanks. ^^
