90 degree angle lock
How is it possible to draw 45 degree wires and lines in schematics ?
ctrl or shift do not switch off the existing 90 degree angle lock.
It takes just one click. You may be able to attach a hotkey to it. Have not done that myself yet.
Regards and succes with your projects,
Bas
Shift + space is the standard assigned hotkey.
(at least for the later v6.x and for all v7.x versions)
Shift + Space rotates the three Line Drawing Modes.
The Icon highlighted by @bask185, plus the two immediately above, will select the different drawing modes.
The same changes may also be made in the Preferences panel shown below.
