9.0.3 Update - Screwed up two Windows PC's
The recent update to 9.0.3 has caused the same issue on 2 separate PC’s.
Steps to re create
9.0.2 installed
Upgrade to 9.0.3
Result - permanent spinning wheel on desktop on right click - Desktop frozen
Did a system restore, Uninstall 9.0.2, clean install 9.0.3 and it seemed to fix it
Windows 11 24h2
Where did you get the install files from?
Did you attempt a second download? Maybe the download went awry.
Also, please add the second dot in KiCad’s version number, Now you’ve posted non existing KiCad versions and this is a bit ambiguous.
