I’m searching for the 8 Way 5V Relay Module footprint but couldn’t find it anywhere,
if someone has it could kindly send
thanks
thanks
Most likely you’ll need to create your own Footprint (and Symbol if desired).
You can place a Screenshot/image of the item and overlay Relays/etc and Traces (Traces can be simple Graphic lines since you need only to hook-up to the Terminals/Relays thus, no need for Traces or even the graphic lines!).
Good Luck!
Roughly created example below… (Relays, PCB Shape, Terminal and corner holes)…
