Hello All,
I have not used KiCad since v6.0.1 which either did not yet work with a proxy or I simply could not make it work.
I am now going to try to start up again with v8.0.1.
When opening the PCM it says “Could not resolve proxy name” which is the same thing it did with v6.0.
I read old advice about setting the environment variable “all_proxy http://:” which I discovered has been set as “all_proxy=http://127.0.0.1:50028” since I set it back then for v6.0.
It did not work back then and it does not work now for v8.0.
Newer advice says to add " KICAD_CURL_VERBOSE 1 and KICAD_ALLOC_CONSOLE 1 to my environment variables to get a troubleshooting console.
I did that and it says “* Unsupported proxy syntax in ‘http=127.0.0.1:50028;https=127.0.0.1:50028;ftp=127.0.0.1:50028;socks=127.0.0.1:50080’: Port number was not a decimal number between 0 and 65535 * Closing connection”
I clearly see that v8.0 does not like the string “http=127.0.0.1:50028;https=127.0.0.1:50028;ftp=127.0.0.1:50028;socks=127.0.0.1:50080”.
But that is what you get when the windows proxy dialog is set like this;
I hope it is the fact that I am doing something wrong.
I really don’t want to have to wait for v9.0 to see if it works with a proxy.
All for now
