I built my PCB with v7 and then moved to 8 and 8.0.1 and when selecting a trace and press E there used to be a check box that would make the trace width the size defined in the Net Class vs a manual entry…
I upgraded to 8.0.2 a bit a go and today I wanted to make some edits. As you can see in this image I have the Net selected but there is no check box to tell it to make the track width the same as the width defined in the Net Class…
Is this a change from 8.0.1 to 8.0.2? Did I change a setting some place on accident that turned that feature off (or is now off by default and I need to re-enable it)? Or do I have a config / settings file that is messed up? Or, or, or???
Thanks for the help!!
