When importing in 7.0rc2 an older project from previous versions (6.0 or 5.1), there are 2 “Default” netclasses as you can see in the screenshot below:
- Open an old project
- Launch PCBnew
- In PCBnew, click on “Edit board setup including layers […]” button on top toolbar, or via menu select “File/Board Setup…”
- Select in left pane “Design Rules/Net Classes” section.
- In “Nectclasses” list, two “Default” rows are visible (and in “Netclass assignments”, no pattern have been automatically created)
- If you try to validate or leave the section, a message says that “Netclass name already in use”
(Also, no pattern was created automatically as stated in topic 7.0rc eeschema - Empty Net Class list?)
Is this a bug? Thanks.
David
Version: 7.0.0-rc2-unknown-f8051d954a~164~ubuntu20.04.1, release build
wxWidgets 3.2.1
FreeType 2.10.1
HarfBuzz 2.6.4
FontConfig 2.13.1
Platform: Ubuntu 20.04.5 LTS, 64 bit, Little endian, wxGTK, xubuntu, x11
Date: Jan 31 2023 20:33:57
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.68.0
ngspice: 38
KICAD_USE_EGL=ON
KICAD_SPICE=ON
